Loose Internal Connector Wire
Poetique
Post by Poetique »
Alrighty, as I griped about a looong time ago, my Predator long ago decided that it didn't want to continue connecting to my truck, so I decided to try to figure out why.
Apparently, one of the connector wires being fed into the circuit board connector came loose. The yellow one on the end, to be precise. As far as I can tell it's not the only one loose, yet also as far as I can tell, there's no way to put it back in.
Might anybody know the particular model of the connector piece used in the 2007 SUV U7194 from the 06-07 model? Also, where it can be purchased?
Or it would be wonderful if Diablo volunteered to send me the piece.
Or if someone wanted to give a quote on how much it would cost to send me a whole new connector cable (OBD-II Port connector to MOBO connector) that'll work too.
Also if it helps, the wire pattern is White - Blue - Green - Brown - Yellow
Poetique
RE: Loose Internal Connector Wire
Post by Poetique »
Bump
Is this unit under warranty?
Poetique
Post by Poetique »
Nope. Not unless yall wanna extend the warranty to 3 years, then I got some months left ;)
Poetique
Post by Poetique »
>_>
Poetique
Post by Poetique »
Annnnnnd bump again...
sceptre
Post by sceptre »
you can't resolder the wires to the board?
Poetique
Post by Poetique »
It's not a soldered design. It uses a small connector to make contact. Granted I could cut the connector port off and PROBABLY solder the wires, it's uncertain as to whether or not that'll work. If the contacts are too small, I can't solder it.
Poetique
Post by Poetique »
And bumped again...
Poetique
Post by Poetique »
Need an answer on this... any answer will suffice.
And just in case someone decides to answer, I have another question
If I have a backup of my original stock tune file, can it be moved to another Predator in order for it to be restored to my vehicle?
dunno about your initial question...
but, as far as the original backup goes... you would have to import the original backup tune file into the predator as a custom tune... then install it to the car as a custom tune...
then you'd have to get the predator reset/unlocked...
then use the predator on the car again and it will save the tune as the "original backup" tune...
that's the only way you'd be able to get it saved in the predator as the "original backup" tune file...
Poetique
Post by Poetique »
W00000 Monte to save the day as usual ;)
Alright... I just wanted to make sure it was possible. Now I just have to find somebody with one that'll work with my vehicle >_<
Return to “Predator GM Gas”
