Help 6/22/2010 u7186_dmx_lly_lbz-9r10.crom update problems
Does this new update have any advantages for a LBZ, if so whats the improvements. Thanks
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
RE: 6/22/2010 u7186_dmx_lly_lbz-9r09.crom update ?
Yes sir, you will get new adjustable timing and fuel pressure parameters.
tech@diablosport.com
7186 Help Please
Downloaded and installed --.DSDownloader_Installer_2the crom file .2.1.9.exe " , then the u7186_dmx_lly_lbz-9r10.crom (978k) Now when plugging into truck when it boots and I go to install tune all I get is the message "Your Calibration is not currently supported " and none of the tunes are there, 45 , 65 , 85 and 120 tunes are gone ???? Then states it will try to restore original backup and then get the message " It was already restored or never saved "Help please Have never had a problem but now it will not show any tunes at all and says it does not have the original backup. I have never never had a problem until this update Help Help Help
Predator u7186
Damon
Predator u7186
Damon
Re: 7186 Help Please
-----------------------------------------------------------------------------------------------------------bigdawg04 wrote:Downloaded and installed --.DSDownloader_Installer_2the crom file .2.1.9.exe " , then the u7186_dmx_lly_lbz-9r10.crom (978k) Now when plugging into truck when it boots and I go to install tune all I get is the message "Your Calibration is not currently supported " and none of the tunes are there, 45 , 65 , 85 and 120 tunes are gone ???? Then states it will try to restore original backup and then get the message " It was already restored or never saved "Help please Have never had a problem but now it will not show any tunes at all and says it does not have the original backup. I have never never had a problem until this update Help Help Help
Me too,
I have a year 7.5 2500hd.
Decided it was time to update the revision from 9r04 to the latest. There was a sticky with a fellow who said he put 9r08 back in and all was fine. I only see 9r07 on the support page but I digress.
How can I find the 9r07 crom? It would be useful to leave older programs up for us in case new flashes don't fit.
Have had predator for two trucks, saved money on fuel (when driven normally) and very stable program performance.
Looking forward to your reply,
V
vitraex wrote:-----------------------------------------------------------------------------------------------------------bigdawg04 wrote:Downloaded and installed --.DSDownloader_Installer_2the crom file .2.1.9.exe " , then the u7186_dmx_lly_lbz-9r10.crom (978k) Now when plugging into truck when it boots and I go to install tune all I get is the message "Your Calibration is not currently supported " and none of the tunes are there, 45 , 65 , 85 and 120 tunes are gone ???? Then states it will try to restore original backup and then get the message " It was already restored or never saved "Help please Have never had a problem but now it will not show any tunes at all and says it does not have the original backup. I have never never had a problem until this update Help Help Help
Me too,
V
- u7186_dmx_lly_lbz-9r08.crom
- (767.45 KiB) Downloaded 179 times
RE: Re: 7186 Help Please
Thankyou for your quick response,
I put 9r08 into the programmer and it works fine. The engine now feels like it is running smoother.
