Can you dissable adaptive shifts
RageZ28
Post by RageZ28 »
Hey all
I have a question 06MonteSS.
I am having problems with the shift feel and timing on my car. I have the pressures maxed for the max firm shift and the shift timing set to quickest. Now when i first install the tune the trans shifts nice and quick and firm. It will bark the tires 1-2 and 2-3 shifts. Once a week of daily driving goes by the thing shifts slow and soft. I can't even come close to full throttle shifts because the thing shifts so slow and soft it slips horrible. Now if I go back in and do a slight adjustment to the perameters and reinstall the tune the trans will shift fast and hard again. The trans is a GM SRTA replacement with about 2200 miles on it. It is at the moment stock so i dont void the trans warrenty.
My question is: can the tune be modified to dissable the adaptive shifts or is there anything else that can be done to fix this problem? I can always put a shift kit in and i already have a servo for it but id prefer not to have to modify it yet. I have removed the tune and it shifts soft and slow on factory tuning.
2002 Camaro Z28 A4 - BBK LT Headers, TSP-X True Duals / Sweet Thunders, SLP Lid and bellows, K&N Air Filter, Descreened MAF, BMR subframe connectors, BMR Xtreme shock tower brace
RE: Can you dissable adaptive shifts
what is the version of software on the Predator?
RageZ28
Post by RageZ28 »
It shows. v.9r15
Wireman134
Post by Wireman134 »
Adaptive shifting is what causes the opposite problem for me, program learns then locks until you reset it with a key cycle. Why shouldn't there be a way to remove this?
2000 Z71 5.3L K&N FIPK, K&N/JBA 3" Cat-back, MAFT, Royal Purple & GC 0w30 lubes. Predator v2.12 w/corrected shifting. Vette Servo.
there are no available parameters in the tune template for adaptive shifting settings at all...
RageZ28
Post by RageZ28 »
Ok thank's for looking. I'll have to do the shift kit then sometime soon. Don't want to kill this new trans like it did the original.
