U7194 question, TM on NBS silverado
-Devil-
Post by -Devil- »
i have an 07 silverado with an engine code of C, i am curious if the U7194 is able to adjust or remove the Torque Management in it? ...
and since the information on the site for it is vague, does it have the same user adjustable options as the other models? ... or is it more limited? if it is more limited, can you post up what is able to be adjusted?
RE: U7194 question, TM on NBS silverado
There is no adjustment for TM in the Predator currently.
It will be added once TCM support is added, so there in no tranny control either for now.
TM is reduced in the tunes, to the point that it should stay out of your way.
-Devil-
Post by -Devil- »
ok so TM is currently being reduced with the tune then ... but no user adjustment at this time.... will it be updateable through the internet when TCM support is added? ... or will it require a new programmer?
Yes, internet update.
