Need help with tuner
RE: Need help with tuner
thats fine...
dasaliac03
Post by dasaliac03 »
ok, im at work right now, i will call andy here in a little while and get him to print me one off and take it to my appartment. should i scan it and email you a copy? i dont have a fax machine at home but i may can find one
dasaliac03
mike, do i need to email you the invoice he gave me or fax it? faxing will take longer but i guess can be done
send it to [email protected] if you'd like.
dasaliac03
just got back from vacation, pulling my camper without any kind of tune on there just sucked. i got an average 12mpg. i have the invoice he gave me in the truck, ill scan it and email it to that link you posted. then what should i do next?
dsquared
Post by dsquared »
After you e-mail the invoice, you must call them. Be prepared to be on hold for a while........... You will need to have the tool powered up (plug into OBD port) and when they pick-up, they will walk you through the button-pushing sequence to reset your tool......
dasaliac03
Mike, whats the number i need to fax it to and then whats the number i need to call?
would emailing it or faxing be better for yall?
fax 561-908-0048
call 800 531 5484
email [email protected]
whatever is easy for you...
dasaliac03
ok, i will let you know when i have the time, i dont think driving down the road posting on here with my iphone is too safe either way so it will have to be when im near the computer at work
how long should this all take?
dasaliac03
mike, i re-attached it to the email. let me know if you got it and when i should call.
dasaliac03
ive tried faxing it a few times now, is that the right number?
Re: RE: Need help with tuner
mikel wrote:If the truck was reflashed and you did not put it backto stock first, you'll need to fax us a copy of the work order shoeing the reflash to 561-908-0048 then call within an hour with the tool powered up so we can unlock it for you.
The Predator will likely need to be updated after that then it will go back in the truck.
once you fax or email the info, call us within an hour or so with the tool powered up please.
