preditor/puck stack with boost fooler
dunejunkie
Post by dunejunkie »
can i run boost fooler with out head stud upgrades, and also does it really lower egts :twisted:
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
madmanwithmouse
RE: preditor/puck stack with boost fooler
Post by madmanwithmouse »
as long as your boost stays under 50psi.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
dunejunkie
so as long as i keep the boost below 50psi the head gasket wont be harmed? how high will the boost fooler let u go? did u notice a diffrance in your egts? mine seem to get high when pull a steep grade loaded, might be nothing i can do about that though..
fyrguy316
Post by fyrguy316 »
i run the stack as well as the predator alone with the boost fooler. when i run either of the performance tunes i've never seen the boost go above 42 psi. when i run the tow tunes and i'm pullin my trailer it spikes around 40 or 42 and will hold a consistent 38 to 40 up a hill. does the fooler help with EGT's? ABSOLUTELY. there is no way to run any of these tunes with out it if your towing. they say you can, but you can't. any time you hop on it the EGT's skyrocket and thats even towing an empty trailer, believe me, i've tried it. now i've never run the extreme tune so i don't what kind of boost numbers would be produced with that one. hope this helps.
05 2500 SLT, 600 cummins, 6 SPD, Predator/Puck Stack, Quad. Boost Fooler, ISSPRO Pyro and Boost, ISSPRO Turbo Temp Monitor, MBRP Exhaust, AFE Stg 2 PG 7, REESE rail setup for 5th wheel or The Goose, PJ Gooseneck 25 ft 14,000 GVW
ropnjessi
Post by ropnjessi »
When I used to run the Extreme tune with no boost fooler I would hit 34psi and that was it...I am curious what I would hit if I had a boost fooler on my ol' 03'...
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
dunejunkie
thanks fyrguy that helps alot . i ordered one today. i noticed my egts climb when i tow, so that will work out perfect for me. maybe i wont have to back out of the throttle when pulling a hill now.
cameroneod
Post by cameroneod »
I've never run a boost fooler, and never thrown a code. I do have the puck. Does it do boost fooling?
ch2037
Post by ch2037 »
ropnjessi, you have to do a wastegate mod to get boost fooling, not the actual BF.
cameroneod, the puck doesn't do BF'ing. Get the BF & you will lower EGT's & get 42 lbs. of boost instead of about 28 lbs. HTH!!
2006 CTD QC 4x4 w/ some goodies :)
ropnjessi
Post by ropnjessi »
I run a HTB2 turbo that has the wastegate already preset at 40psi, I can turn it up if needed.....since I posted my first question I did buy a boost fooler and saw no increase in psi.
ch2037 wrote:ropnjessi, you have to do a wastegate mod to get boost fooling, not the actual BF.
Dodgezilla
Post by Dodgezilla »
Running over 40psi on a stock turbo consistantly will greatly shorten the life of the turbo.....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
Rick
Post by Rick »
Running puck only with boost fooler.
Boost fooler did reduce EGT's.
Without fooler it was easy to hit 1300+ while getting
kinda stupid!.
With fooler I can stay in it much harder and longer and
never hit the 1300 mark!
2006 Quad cab 4X4. Auto. 3.73 posi. K&N intake.
Powerpuck. Autometer 3 guage stack.
Rick
Post by Rick »
FOLLOW UP!!
I forgot to mention..
Without boost fooler, max pressure was 30 PSI.
With quadzilla fooler I am hitting 36-38 PSI.
I think the extra air is what is helping keep the EGT down.
Dodgezilla
That's the idea... :wink:
dunejunkie
ordered the boost fooler 3 weeks ago from truck addons, still havent received it ,but i cant wait. they keep giving me the run around wont use them again!!!
MattD
Post by MattD »
Sorry about the issues with truckaddons.com. I am completely out of the boost foolers and have been for some time. Who have you been dealing with here? I'm sure we placed your order with Quad for it to be direct shipped to you.
Shoot me an email at [email protected] with your information and I'll see what I can dig up for you.
2012 Ram 1500
