PATS, 5.4L 3V QUESTIONS
KARASKUSTOMS
Post by KARASKUSTOMS »
here you go
RXDG4B2HEX.frg
(615.62 KiB) Downloaded 436 times
try these please
rxdg4b2hex_pats1.frg
(449.9 KiB) Downloaded 425 times
rxdg4b2hex_pats2.frg
(449.9 KiB) Downloaded 464 times
rxdg4b2hex_pats3.frg
(449.9 KiB) Downloaded 444 times
let me know...
KARASKUSTOMS
You got it
KARASKUSTOMS
same problem
what is the issue exactly, word for word please.
KARASKUSTOMS
Here you go
after hitting continue<br /><br />then I just unplug, because it just reboots and does the same thing over again
scroll down to this
scroll down to this
first error
first error
looking into it...
KARASKUSTOMS
thanks
Ok, think this will do it.
Restore the stock tune, then update the Predator to this new version.
The tunes should load fine then.
u7151_f150-9t11a.crom
(980.76 KiB) Downloaded 527 times
The tunes willwork, but you will want to export a new copy of the original backup file and use it as your base file when loading the tunes I posted.
Actually, once you get it updasted, let it read the backup, post it here, and we'll have to make new tunes afterall, will take me 2 minutes ;)
KARASKUSTOMS
Here it is
RXDG4B2.frg
(615.62 KiB) Downloaded 449 times
Try these please:
rxdg4b2_new_pats2.frg
(449.9 KiB) Downloaded 467 times
rxdg4b2_new_pats1.frg
(449.9 KiB) Downloaded 458 times
KARASKUSTOMS
IT RUNS!!!!!!!
Mike if i could reach thru this computer and kiss you I would.
Thank you so much for all your help, I've been trying to get this running for months and you solved my problem.
Thanks again.
p.s. I used the first tune, is there any need for me to try the second one?
Return to “Predator Ford Gas”
