Instant Results?
ALK
Instant Results?
Post by ALK »
Sometimes when you think to much you get confused. When you make an adjustment on your Predator (7194) to adjust the LTFTs. Are you INSTANTLY changing the amount of fuel to the engine and it takes a while for the computer to adjust to the added or decreased amount of fuel you have altered?
RE: Instant Results?
LTFTs will have to learn, WOT changes take effect right away.
ALK
Post by ALK »
Mikel, still didn't answer my question. When you move the scale on the Predator from say +1 to +2. What have you done and where are the results. Immediately did you tell the injectors to spray more fuel, less fuel, at idle, part throttle, WOT, what and where. :?
Telling the PCM that you have larger injectors will cause it to spray less fuel at all times.
ALK
Post by ALK »
THANK YOU!!!!!!! :D
Return to “Predator GM Gas”
