Instant Results?
Instant Results?
Sometimes when you think to much you get confused. When you make an adjustment on your Predator (7194) to adjust the LTFTs. Are you INSTANTLY changing the amount of fuel to the engine and it takes a while for the computer to adjust to the added or decreased amount of fuel you have altered?
RE: Instant Results?
LTFTs will have to learn, WOT changes take effect right away.
Telling the PCM that you have larger injectors will cause it to spray less fuel at all times.
