Advanced Trans Tunning 2010 Ram 1500
Is there going to be Advanced Trans Tunning available for the 2010 Ram 1500. I know superchip has it available for their product. Just curious to where you guys are at?
Also I live up in northern bc and there is no dealer that does custom tuning near me. Is there a way I can get programming to play with custom tunes my self?
I'm enjoying the program so far besides these few things. I eliminated the ESP already which made a bit of difference fun wise.
Thanks.
Jesse
Thanks.
Jesse
RE: Advanced Trans Tunning 2010 Ram 1500
We have (and have had for some time now) access to all of the parameters in the TCM through our CMR dealers, just has not been popular for them to play with it for whatever reason.
So I have to goto a CMR dealer to be able to have my Torque Management adjusted?
Is there any way for the public to get the program to have access to all the parameters in the TCM?
Most of the TM you guys think you are feeling is in the PCM.
Send me your tune, I'll hook you up.
okay thanks. I will get it to you asap.
Also my vehicle is used for offroad use only. Is there a way in the TCM to turn the ESP off? I have it disable right now via wheel sensor unplugged.
I'll see what we can do...
This should be it here. Its a 93 tune with neg 8 deg timing because of fuel currently using.
Jesse
Jesse
- Jesse Last Tune Written.drg
- (4.25 KiB) Downloaded 224 times
8*?
Thats less timing than you'd run stock, what is it, water?
here you go
- jesse_last_tune_writte_001.drg
- (73.78 KiB) Downloaded 211 times
So, you get KR withthe stock tune too?
- fordomatic69
Wow, 8* is really high. I'd start with the canned 93 and add fuel in 5% increments to a max of maybe 10 or 15% before pulling timing.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
