any one here have a c5 corvette
tonys01c5vette
Post by tonys01c5vette »
looking to gain about 40 to 50 horse and want to do it with out spending alot of cash. so far i have u7198 with version 2.13 oem replacement k&n filter and a velocity stack with a smooth air coupler.
edv2122
Post by edv2122 »
I had one, add a good set of headers and you should be close, do a cam and you will exceed your goals. Without spending alot of money there is not much more you could do. There is a Vette tax on most parts so expect to pay more for things then a comparable part for a honda.
Yeah, a cam and longtubes will wake that thing up like you would not believe.
I am also a fan of the Vararam CAI, as it adds a solid 2-3 mph in the 1/4 on an otherwise stock car.
tonys01c5vette
these long tube headers do you have to cut your x pipe or how do they work? Im just wondering if i have change whole exhaust dont care much for noise when traveling on interstate
tonys01c5vette
hey mike the guy with the monte told me to lean pe i lowered both the low one to -2 and the high one -3 better gas milage but a little sluggish when stepping down like at 30 mph at 120 02 sensor reads about 915 was at 935 at take off both at 905 when hitting the throttle what is a good number to have?
If it feels sluggish it may want a bit more timing or some fine adjustments to fueling.
PE is only at WOT, so I'm not sure how it would affect mileage.
tonys01c5vette
so i should advance timing maybe 2%
Give it a shot.
Limp1
Post by Limp1 »
I have longtubes on my C-5, (2004) and it makes a big difference, but, if you don't want noise, Forget It!
tonys01c5vette
[quote="Limp1"]I have longtubes on my C-5, (2004) and it makes a big difference, but, if you dondid you by the cats with them or did you cut the flanges? which brand did you by?also do they hang real low and loose ground clearance?
Limp1
Post by Limp1 »
tonys01c5vette wrote:
Limp1 wrote:I have longtubes on my C-5, (2004) and it makes a big difference, but, if you dondid you by the cats with them or did you cut the flanges? which brand did you by?also do they hang real low and loose ground clearance?
I bought the LG Pro Longtube Street Header system, polished stainless steel to their x-over pipe, with the cats, to Borla Stingers with quad tips, Great system, beautiful sound! No clearance problems, but a little tricky to get the tips to line up properly. I get tired of hearing people say that they put on headers and now the car is louder, or they hear drone...for those people, Leave it stock! ....good luck....bob.
FastBlueSS
Post by FastBlueSS »
How much longer till TCM support?
