the download section ?
03 ford f250 superduty 6 litre deisel .in the download section how do i no what tune to use ?where does it say weather it is 65 hp tune or 100hp tune ,iam running a 60hp tune probably a few years old i want to see an updated 65 hp tune ?also how do i tell what tune is on my truck for sure ?thanks for help here bit confused !
RE: the download section ?
this is what ineed to no also in the download section for my truck 03 6 litre deisel there are 3 downloads A R17 A R10 A R84 how do i no what tune it is like are they all 65 hp tunes or what ?and which one should i use ?thanks confused here and dont want to srew my truck up
For starters, before updating, you need to reinstall the stock tune.
Then, read through the 'revision update instructions' found at the bottom of the downloads page.
Then, power the tool up to see what revision it is on currently. If it says 7r84, you need to do 8r10 then 8r17.
If it is on 8r10, you can go straight to 8r17.
what happens if iam not happy with the new tune is there anyway to put the old tune back on ?[not factor tune ]the tune that is on the programer when i plug it in says V.8R13 is this good or bad or is there a better one ?also it says v17 tune is for 2005-2007 with it still work on my 03?
