Please Read and DO NOT IGNORE !
ummm... the speed limiter is already set to 200mph in that tune file... which is 322kph....
how about you do a new fresh export of the "last tune written" tune file and post it up here... maybe you never imported the tune correctly...
I see this ALL the time...
Hello,
Thanks for your support here is what i did
i have installed Diablo sport tune and reseted all parameters so that you could remodify the rpm rev limit and topspeed
quick question.. which has higher performance the diablo tune or the 91 octane?
thanks again
thanks again
- DIablo_Tune.grg
- (3.25 KiB) Downloaded 141 times
diablo tune... it is made for 93 octane gas (98 octane over where you are)... so it has more advanced timing...
but, if you only use 91 octane gas (95 octane) in the car, then use the 91 octane tune...
why'd you reinstall the diablo tune again??? uugghhh.. . I wanted you to do an export of the last tune written, which would have been a copy of the last tune you installed, so I could compare it to my file to make sure you did the import to the tool correctly, and was installed to the car correctly...
making you the same tune again isn't going to make a difference if you're not doing the import to the tool correctly, that's what I wanted to check...
so now, use the custom tune file I gave you before... import it to the tool, and then install it to your car....
drive your car for a bit and check it out...
then, hook up the tool to your PC, and export a new fresh copy of the "last tune written tune" file and post it up here so I can check it out... if all goes well, that file should match the custom tune file I gave you....
so.. the custom tune I gave you is installed in the car right now??? you said above that you reinstalled the regular diablo tune...
so, which tune is in the car now???
hello,
I have installed the tune and took a backup before i test the vehicle i have tested it today and it's still 245 KMPH however the RPM rev upto 6++ with no problem just the speed limit problem here is the backup you requested
thanks for your support !
- alfanooos_166_modified.grg
- (3.25 KiB) Downloaded 144 times
when you asked for a fresh copy i removed your tune and put diablo tune then took the backup after that i removed the diablo tune and put back yours and took the backup i posted above..06MonteSS wrote:so.. the custom tune I gave you is installed in the car right now??? you said above that you reinstalled the regular diablo tune...
your tune does great with the rpm just not with the speed limit
sorry for confusing you
heh, that's not my exact tune file...
looks like you bumped up the idle +400rpm... but, that doesn't matter about the speed...
what DOES matter is - the tire size is changed... normal stock setting is 751.5 revolutions per mile...
whatever you changed it to, it's now at 256 revolutions per mile... those are some big-ass tires!!!
so, your speedometer is off man... heh...
