then once that is done, I turn the key off and take it out, I disconnect the negative battery cable, step on the brake pedal a few times and turn the headlight switch on (to drain any residual power left in the system). I do this to reset any "learned" parameters by the ECM, such as fuel trims.
My question is, what else would get reset by doing this?
I've seen in another forum that someone said it would also reset timing/spark tables. so does that mean the the timing/spark settings I just installed with the tune are now gone and are back to stock/original settings?? Do I need to reload the tune again after reconnecting the battery cable??
Thanks!
