U7130 + PowerPuck U7131 - Codes?
KSzabo
Post by KSzabo »
So I got my Predator U7130 and installed the Performance tune, although my Powerpuck (it has u7131 on it) is disconnected due to P0193 codes, I was wondering will it still throw these codes if I install the stacker tow tune and hook the powerpuck back up. Or is the fact it was throwing these codes without the Predator installed indicative of a Powerpuck internal failure?
RE: U7130 + PowerPuck U7131 - Codes?
Tough to say, but that would be a great way to troubleshoot it.
KSzabo
Post by KSzabo »
As the Powerpuck is still in the truck but disconnected from the engine I can reconnect it again and then change the Predator to stacked tow and see if it still throws the p0193 codes. Hopefully the Predator will let me clear them if it does.
Does it make any difference which connector (blue or orange) goes to the MAP sensor and which goes to the fuel rail pressure sensor? There are two males and two females does it make any difference which female goes to which sensor and which male goes to the wire harness connectors? In addition to the U7131 on it it also has a D7157 on it.
