I bought an 01 Dodge 2500 Diesel with a Power Puck installed. Sometimes when I drive the truck there is a breif stall/ loss of power. This didn't happen when I test drove it, but happened after a few hours of driving. Also the next morning it happened about 20 times on the side roads and the highway. This mostly seems to happen around 55.
I would like to remove the power puck and see if the problem goes away. Can I simply unplug all the connections?
Also, I'm curious what the power puck does for fuel economy... I understand it helps with power, but does it reduce fuel economy by creating more power?
Bought a truck with a power puck. Problems - remove?
RE: Bought a truck with a power puck. Problems - remove?
Yes, disconnect it and reconnect the factory plugs and it will run like stock.
Economy can be improved by 2-3 MPH with the pucks depending on driving style.
