Cruise Control issues
lineman247
Post by lineman247 »
Should a man load back the stock tune before taking it to a shop?
2004 Dodge Ram Hemi QC
u7137
09t08
93 tune Loaded
Yes.
butch1581
Post by butch1581 »
Just an update:
Since the sensor replacement, I have loaded the 93 tune and have not had any issues. I sure was sick of driving that thing with the stock tune loaded!
Always load your stock tune when bringing it to a shop!
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
lineman247
So I loaded back the stock tune today and cruised worked just fine. I then loaded back the 93 tune and cruise......still works?!?!? Dont really know what happened. Any thoughts?
u7137
09t08
93 tune Loaded
lumpy69
Post by lumpy69 »
Any updates on this? Anybody?
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
lumpy69
Post by lumpy69 »
Bump
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
lumpy69
Post by lumpy69 »
BUMP
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
Have you tried disconnecting the battery?
lumpy69
Post by lumpy69 »
The battery,the fuse,back to stock,new croms,older croms,no luck Mike.
Like I said in previous posts,it started with the beta crom,other than this
glitch,all is great.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
butch1581
Post by butch1581 »
did you try loading the stock tune back into the truck?
Predator
V.9r11
lumpy69
Post by lumpy69 »
Yes I did,no luck and dealer shows no codes.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
lumpy69
Post by lumpy69 »
BUMP
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
Interesting.
aDaMpHiZzLe
Post by aDaMpHiZzLe »
I have a 05 ram 1500 with a hemi and when i installed my u7137 about a year ago i have had the same cruise control problem ever since. It cuts off at about 65mph but if you set it on 60mph it cuts off in about 2 min. that is with 9r09 i am just now installing 9r12... ill post if anything changes.
scarface6
Post by scarface6 »
I'm having the same problem. Installed the u7137, 9r12 and the abs and brake light came on. Tried different tunes, set it back to stock, unhooked the battery - no change. Cruise won't work now either. I have a 08 ram 1500.
