NEWBE POWERSPORT M2020 2007 CAT C7 IN FREIGHLINER MOTORHOME
MNICHOLS4
Anyone have any suggestions for installation and user adjustment? Is it necessary to run the adjustment pot all the way to the dash. I have a 40 foot motor home. Should you adjust on the fly or set it and leave it? The engine is a Cat C7 350 hp. How about results?, ideas on what I can expect. Anything to watch for so I don't damage the engine. Thanks in advance !
RE: NEWBE POWERSPORT M2020 2007 CAT C7 IN FREIGHLINER MOTOR
You dont need to adjust on the fly, you could experiment with settings and then leave it where you like it best.
MNICHOLS4
Mikel
There is a real lack of info for the use of the power puck, or I have not been able to locate it. What indicators will tell me it is working properly?
I just got the puck installed in the motorhome and I'm worried that the 2 sensor connections are identical and there is nothing in the instructions to tell you which goes to which motor sensor. The motor started and ran installed the puck so I assume this is a good indication I have the right connector on the right sensor. Can someone confirm this ?
