? 4 dulleydave or johan or mikel
i read on another post guy was asking about tm with the 7130 u said it more like a motocycle dullydave..wich update is this because i cant get seem to get answer from anyone..i dont care if it idles ruff
- duallydave
RE: ? 4 dulleydave or johan or mikel
hi dyork,the file u are talking about is the r28 and it didnt idle rough it idled really high and would rev and stay there when u barely touched the throttle,the tm tunes were cool,very responsive pedal,i have the r28 and the tunes,if u have calid #15xxx then i can email them to u,i wouldnt recomend it though,it was hard to drive with the idle thing,im sure when johan gets some time he will play with the tm again,he drives a cummins and knows the need for throttle responce.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
ok then wich one do u suggest im looking for little better pull like when i put my buddys bullydog with crazylarry and my puck on my truck
o5 cummins auto 14.56 1/4.on (diablo u7130..k&n cold air 5'' turbo back straight) i now have .transgo shift kit.tci billet converter
- duallydave
im using ext rkl puff with no timing,i had slight timing rattle with it with added timing so the non timing tune is working well for me,ext rkl puff should be pretty close to crazylarry im sure.i woulnt bother with the puck,on the extreme tunes i dont think you notice much diference.
does the timing one have anymore pep
- duallydave
not that i noticed,some say the timing advancment will net more mpgs,im pretty happy with the tune im using now
the calid #25325373aa...can u send me the tm tune and the tune u are running now.. my email is [email protected] thanks
- duallydave
sorry dyork,i have calid 15xxx,the tunes i have wont work,post on here im sure some one who has the same calid has the tm tunes and r28 crom,u need to load the r28 crom to make the tm tunes work first.as far as the tunes im using you can get that in the sticky on the top of this forum,download the ext rkl puff.tunes they have the ext rkl puff no timing in there.
