preditor/puck stack with boost fooler
dunejunkie
can i run boost fooler with out head stud upgrades, and also does it really lower egts
06 mega cab predator/puck stack,afe stage 2,cfm+ plentum,zilla boost fooler,maghytec deep trans pan, a-pillar gauges and 5 inch exhaust
- madmanwithmouse
RE: preditor/puck stack with boost fooler
as long as your boost stays under 50psi.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
dunejunkie
so as long as i keep the boost below 50psi the head gasket wont be harmed? how high will the boost fooler let u go? did u notice a diffrance in your egts? mine seem to get high when pull a steep grade loaded, might be nothing i can do about that though..
i run the stack as well as the predator alone with the boost fooler. when i run either of the performance tunes i've never seen the boost go above 42 psi. when i run the tow tunes and i'm pullin my trailer it spikes around 40 or 42 and will hold a consistent 38 to 40 up a hill. does the fooler help with EGT's? ABSOLUTELY. there is no way to run any of these tunes with out it if your towing. they say you can, but you can't. any time you hop on it the EGT's skyrocket and thats even towing an empty trailer, believe me, i've tried it. now i've never run the extreme tune so i don't what kind of boost numbers would be produced with that one. hope this helps.
05 2500 SLT, 600 cummins, 6 SPD, Predator/Puck Stack, Quad. Boost Fooler, ISSPRO Pyro and Boost, ISSPRO Turbo Temp Monitor, MBRP Exhaust, AFE Stg 2 PG 7, REESE rail setup for 5th wheel or The Goose, PJ Gooseneck 25 ft 14,000 GVW
When I used to run the Extreme tune with no boost fooler I would hit 34psi and that was it...I am curious what I would hit if I had a boost fooler on my ol' 03'...
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
dunejunkie
thanks fyrguy that helps alot . i ordered one today. i noticed my egts climb when i tow, so that will work out perfect for me. maybe i wont have to back out of the throttle when pulling a hill now.
cameroneod
I run a HTB2 turbo that has the wastegate already preset at 40psi, I can turn it up if needed.....since I posted my first question I did buy a boost fooler and saw no increase in psi.
ch2037 wrote:ropnjessi, you have to do a wastegate mod to get boost fooling, not the actual BF.
cameroneod, the puck doesn't do BF'ing. Get the BF & you will lower EGT's & get 42 lbs. of boost instead of about 28 lbs. HTH!!
Dodgezilla
Running puck only with boost fooler.
Boost fooler did reduce EGT's.
Without fooler it was easy to hit 1300+ while getting
kinda stupid!.
With fooler I can stay in it much harder and longer and
never hit the 1300 mark!
kinda stupid!.
2006 Quad cab 4X4. Auto. 3.73 posi. K&N intake.
Powerpuck. Autometer 3 guage stack.
Dodgezilla
dunejunkie
Sorry about the issues with truckaddons.com. I am completely out of the boost foolers and have been for some time. Who have you been dealing with here? I'm sure we placed your order with Quad for it to be direct shipped to you.
Shoot me an email at [email protected] with your information and I'll see what I can dig up for you.
2012 Ram 1500
