Corvette Z06 My 2009
VETTESHARK
RE: Corvette Z06 My 2009
Post by VETTESHARK »
Thanks Mikel, how can i do it?
Is for this reason that I have the messages "SERVICE ACTIVE HANDLING SYSTEM" , "SERVICE TRACTION SYSTEM" and on the display the logo of the engine malfunction?
Can I damage the car driving with the logo of the engine malfunction?
What do you advise me to do?
Those are normal after a reflash, aslong as they do not reappear it is fine.
VETTESHARK
..... but those error messages are always fixed on my display. Are you sure that I don't damage engine using the car?
VETTESHARK
Sorry, I forgot to say you that on my car are mounted:
1) Kooks long tube headers and x pipe cat
2) Killer Bee II air intake and Beehive (included with the intake)
They should not be there all the time....do they stay if you restore the stock tune?
VETTESHARK
Dear Mikel, as already written above I reinstalled Original Back-up = No change
Or rather, setting in motion the car (with Original Back-up installed) for the first few minutes don't show warning messages, but after about 15/20 minutes compare the same messages: "SERVICE ACTIVE HANDLING SYSTEM" , "SERVICE TRACTION SYSTEM" and on the display the logo of the engine malfunction.
I disconnected battery for 5 minutes = No change.
I want also note that before installing the Trinity I never had problems.
Is the trinity plugged in while this is happening?
Does it go away if you unplug the trinity?
VETTESHARK
Dear Mikel, the malfunction messages also appear when the Trinity is not connected. Yesterday I used the car in stock configuration, no tuning. After about 100 km is on the light engine fails. As I said my car mount collectors of Kooks long tubes, it's possible that the engine light comes on from the CO2 sensor? Do you think I can damage the engine if I continue to use the car?
Thanks for your help.
yes, you are getting the trouble codes for the O2 sensors because of your headers...
VETTESHARK
But if I use the car , may the engine have some problems or can I ignore the engine light on the instruments panel?
VETTESHARK
up :cry:
you can ignore it if you like, it will not cause any issues.
Return to “Trinity GM Gas”
