7194 incompatible hardware
Primed67
Post by Primed67 »
I was trying to update my predator to the newest version tonight and downloaded the newest downloader also. When I went to install I'm now getting CROM7194-v.9R16 Incompatible hardware contact tech support. I have never had a problem in the past updating it, whats different now?
killerrf
RE: 7194 incompatible hardware
Post by killerrf »
its your 7194. its old and doesnt have enough memory for the big crom file. mine did the exact same thing. old ass pred is the problem. i emailed tech support and they gave me v9r10 which worked. nothing above v9r06 needs to be updated. just calids added i believe for more support.
revision 9r08 or 9r10 is all you need to be on for your 07 truck... nothing new for it after 9r08....
check here for the previous revision update crom files...
http://forum.dslogredux.com/index.php?topic=35.0
Primed67
Post by Primed67 »
I'm back up and running now. Guess I need to look more into working with the paramaters to get more out of the tune. Just not really sure on all that yet. Thanks for the help! Tim
07 1/2 Ton 4x4 GMC sold
08 3/4 Ton 4x4 Crew Cab Ford 6.4
