WOT Fuel adjustment
BlackR/T6Speed
WOT Fuel adjustment
Post by BlackR/T6Speed »
Just had two quick questions. I've got a 2009 Chally R/T six speed with CAI, thermo, catch can, catless mids, E3 spark plugs, and resonator delete pipes. What would be a good starting point to set my WOT fuel ratios at? And does anyone reccomend messing with the spark? I'll be taking it to the drag strip in a few hours.
RE: WOT Fuel adjustment
Add 10% fuel for the mids, and run the CAI tune.
crf450rr
Post by crf450rr »
Get rid of the E3s...
yeah, E3's are junk... lotta problems with those plugs...
2010RAMRT
Post by 2010RAMRT »
What's the problem with E-3's?
I have set in my hands here that I was planning to install this afternoon!
2010 RAM HEMI
have seen/read a lot of people have issues with them, like a lot of misfires and such....
fixed the problems and regained their performance by going back to stock plugs...
2010RAMRT
Post by 2010RAMRT »
2010 RAM HEMI
are we repeating ourselves here??
ok, I'll play along...
search around forums...
brandy16
Post by brandy16 »
I did not know they made E-3s for the 5.7. I looked them up and got a message saying they did not make a plug for my car. That said these guys are correct. Get rid of them. The reason people have trouble with them is they retain to much heat at the electrode which will cause the mixture to fire prematurely (before the spark plug fires) The original plugs are copper clad for better heat dispersion...
2010RAMRT
Post by 2010RAMRT »
Apologies for the double post there. Don't know how that happened.
The part no. for Hemi E-3 is 3.68.
So, I passed on the install. Now I have an expensive set of new plugs that don't sound like a good choice.
Do you have any experience or recommendations for plugs for a Hemi that make a difference?
crf450rr
Post by crf450rr »
Champion stock # 570 plugs are about 2 bucks each...
Do a search over on the LX forums and you'll see most everyone that tried the E3s started having misfires or the car just started running like crap at 1000 to 2000 miles...
Charger250
Post by Charger250 »
Any issues with platnum or iridium plugs?
brandy16
Post by brandy16 »
Best bet is to go with the factory plugs (champions) There is no advantage in the high dollar plugs its just a gimmick.
Charger250
Platnum plugs are rated at 100k miles. Thats an advantage. Some cars have them stock so the manufacture can say the car has a 100k miles per tune up.
bighemitex
Post by bighemitex »
Charger250 wrote:Platnum plugs are rated at 100k miles. Thats an advantage. Some cars have them stock so the manufacture can say the car has a 100k miles per tune up.
platinum plugs on a hemi is a no-no. guys that were using platinum plugs in hemis were having issues with the platinum coating on the electrode melting off then you might have the issue of the platinum chunk bouncing around the cylinder and a spark plug that isn't working properly. Copper plugs are the best way to go on these engines. I wouldn't put those stock champion plugs in any thing i own so I switched to NGK v power plugs
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
