U7135 Is shift firmness increased in the Performance Tunes?
nagelm123
Post by nagelm123 »
Searched but couldn't find an answer.
I'm assuming it is....
TIA!
Matt
RPaulG87
RE: U7135 Is shift firmness increased in the Performance Tun
Post by RPaulG87 »
Mine kicks like a muel going from 1st to 2nd with the 6.1l...so I guess so? What exactly is "shift firmness"? I could be mistaking it, it's very on time...just rough.
6.1, yes, 5.7, no....
nagelm123
Re: RE: U7135 Is shift firmness increased in the Performance
Post by nagelm123 »
mikel wrote:6.1, yes, 5.7, no....
Thanks!
I've got an R/T (5.7). Can I modify the firmness in the performance tune?
RE: Re: RE: U7135 Is shift firmness increased in the Perform
Yes, under quick adjust.
RPaulG87
Re: RE: Re: RE: U7135 Is shift firmness increased in the Per
Post by RPaulG87 »
mikel wrote:Yes, under quick adjust.
I can't find this, all I see is raised\stock shift points...
nagelm123
Post by nagelm123 »
I'll try later and report back....
RPaulG87
Post by RPaulG87 »
I did some research and apparently it's under "stock tune modify" so I don't know if that even effects it if you're using a diablo tune :-\
RE: Re: RE: Re: RE: U7135 Is shift firmness increased in the
No, it is in the Quick Adjust menu, you dont want tomodify the stock tune.
RPaulG87
Re: RE: Re: RE: Re: RE: U7135 Is shift firmness increased in
Post by RPaulG87 »
mikel wrote:No, it is in the Quick Adjust menu, you dont want tomodify the stock tune.
Could you show me where shift firmness is then, because I can't find it I just went down to plug it in and check, I see axle, shift points, dyno, and tire size...that's all under quick adjust...and under shift points it's raised or stock, no firmness setting :-\
RE: Re: RE: Re: RE: Re: RE: U7135 Is shift firmness increase
what is your calibration ID?
RPaulG87
Re: RE: Re: RE: Re: RE: Re: RE: U7135 Is shift firmness incr
Post by RPaulG87 »
mikel wrote:what is your calibration ID?
I'll have to find that out next time I go out, what would that change? I originally used this on a 300c SRT-8 (2008) and reflashed it to 9r27 for the Challenger...does the 91 octane perf tune change firm shiftness? if it does then that would explain the kick I get now going from 1st to 2nd which causes the tires to bark..
nagelm123
Post by nagelm123 »
Easy...
Go to Performance Tunes
You will have to accept, then turn key on, continue
Then to Quick Adjust
Then to Transmission and then you'll see it.
RPaulG87
Post by RPaulG87 »
nagelm123 wrote:
nagelm123 wrote:
RPaulG87 wrote: I can't find this, all I see is raised\stock shift points...
Easy...
Yeah mine doesn't have that option :-\
RPaulG87
Post by RPaulG87 »
OK from what I've gathered SHIFT firmness is not available on 6.1l models..why is this? :-\
