still waiting on next step to take for the rough idle mike/
as soon as i install the u7131 my idle starts to get rough, the whole truck shakes tried different power levels but the same, it sounds like in the exhaust like the engine is missfiring, I have the r16 downloaded as well. I guess ill just take it out again till we get some answers about this. As soon as i remiove the downloader the idle is as smooth as silk and even with my edge, Dr performance stack its smooth so is there a new flash for this symptom is is this downloader as good quality as the rest of them.
06 ram mega 3500 4x4 srw laramie.many add ons to make it a 13 sec 1/4 mile truck.
RE: removing u7131 till i get some answers on rough idle
also this symptom seems like it started to get worse as time went by, when i first flashed the predator and had it in there it seemed fine and i had it in there for a month or so and then it started this symptom.
In both drive and neutral? I am assuming you have an auto?
2003 Silverado 8.1 Allison
Try doing a full restore of the tune:
Options/
Troubleshooting/
restore original backup
Do this, then try reinstalling the tune from the new update, and it should fix the issue.
Options/
Troubleshooting/
so when i took it out i went to performance tunes and then restore original back up, now with this done do i have to go thru ther steps that you provided or do i have to download it in the truck first then do the steps you specified? Also when i do the steps you specified when you mean do a full restore do you mean do to my pc and upload the r16 again to the predator or something else? It idled rough all the time you can hear it in the exhaust that its almost miss firing or something.
What I mean by full restore is to follow the steps I outlined above and let it write the complete stock tune.
Once that is done, go ahead and apply the tune from the Predator.
well Mike round 2, tried what you said i got to the spot to try to restore original; backup and it said.>>> cant restore original backup it was already restored or was never saved>>> This is as far as it will let me go unless i want to load a tune again which i dont till we know why it idles like crap>
if you need my calibration id is 35325853ag i know about the ag becaused i flashed it to the latest update after i took the predator out.
need help still, havent done anything yet since last instruction you told me to try>>>
Is there a tune in the truck?
It will not let you do a full restore if there is already a stock tuneon the truck.
When I had my suprchips installed, I think that if I took the stock tune out, but left in the tire diameter change, the tuner did not consider itself entirely removed from the truck. It may be the same for high idle, I am not sure.
FYI & good luck.
FYI & good luck.
By the way, what is your build date? There was an ECM change in 6/06. My truck build date is 6/06. So I don't know which ECM I have. But I have read that some companies have had trouble with the 06.5-07 tuners being a bit confused when working with programmers.
yes mike i think its totally out, when i removed the tune from truck i went to the area where you can pick what tune you want, eg tow, performance, extreme etc and then scrolled to the [restore original backup line and picked it] then it asks you are you sure bla bla bla, then the 5 min wait. Is there something else i should be doing?
Like I said....please apply a tune, then, if you did not do so, go to options/troubleshooting/restore original backup.
If you restored in the manner you just described, it will not fix it.
ok i loaded the tune again in the truck then did the total restore like you said to do, drove truck a bit then reloaded the tune in the truck again on extreme and is much better for now. Time will tell if it stays this good because this is what it did the first time but it took a while then started to idle rough. Thanks for your help.
