Our shop purchased the U7193 for the 05 Chevy Z71 (Vin B)...truck lights up the ABS and says E-brake is on. And yes, we are using the newest tune [just updated by you folks].
Is this a known issue??? Do we need to look elsewhere for the problem??
Chris
2005 Chevy Z71-ABS Light
RE: 2005 Chevy Z71-ABS Light
Stock tires and gears?
Did you make any other adjustments to the tune?
No changes to tune except tire size (rev per mile).
Stock engine 5.3 Ltr
Stock gears
Z71, 4X4
Stock gears
Z71, 4X4
Vehicle is running Toyo Open Country M/T 37X13.5X20
...with a 12" lift
...with a 12" lift
yeeaaahhhhh... . that size is most likely out of the allowable range of the abs system...
It should be within range...predator can adjust up to 40" tires.
That does not mean the PCM will be happy with what you tell it though.....
