timing advance
rletzgus
timing advance
Post by rletzgus »
OK got my new Predator U7198 update to the new version. I installed the diablo tune using 93 octane. Before the update I could advance the timing to 20 in all rpm ranges with no knock. Now the new version will say only up to 10 (degrees).
New version says advance in degrees. The old version said advance to 20 but not in what increments. Come to find out the old was percentage advance, so if I advanced 20 it would be 20% of what the cuurent degrees of timing was. So what is the new version and why only 10? my old version tune had more umph than the new version. ????
2001 GMC Sierra
4.8L
K&N FIPK Cold Induction
Headers
2.5" duals with Delta 50 Flowmaster
B&M tow shift kit on 4L60E
Predator U1798 ver 9r15
MSD Ignition MSC Multispark coils
RE: timing advance
old version was in percentage... new versions are in actual degrees... you actually have MORE adjustability now...
for example, if timing at WOT is 24*.... then you can adjust say, +20%, well that's only 4.8* change... with the new version, you can go 10*!
other things in the tunes could have changed between the older version and the new version... maybe why it feels different...
rletzgus
RE: timing advance
Post by rletzgus »
k thanks for the info. I have mine advance 10 Degrees, but am not actually getting that, with no knock retard. I'll check again though. Anyway anyone know how much advaced timing is negating the advance in the first place?
2001 GMC Sierra
4.8L
Headers
gregs
RE: timing advance
Post by gregs »
just wondering, what rpm range you're advancing it 10 degrees? that seems like too much
03 Silverado 1500 Z71 EC/SB
RE: timing advance
yeah, for sure!! hell, when I do my custom tunes for people, I usually have to REMOVE timing in areas...
the diablo tunes have the timing pretty jacked up as it is... I wouldn't add any more to it....
rletzgus
RE: timing advance
Post by rletzgus »
10 degrees on all ranges. I checked it and no knock retard.
2001 GMC Sierra
4.8L
Headers
rletzgus
RE: timing advance
Post by rletzgus »
advancing timing only happens at full throttle right?
2001 GMC Sierra
4.8L
Headers
RE: timing advance
yes...
BUT, remember, even if there's no KR, it doesn't mean you're gaining anything... you reach a point where, adding more timing, will actually HURT performance...
and fricken 10* is a LOT man...
like I said, I wouldn't touch the timing at all... it's jacked up pretty high in the diablo tunes already man...
RE: timing advance
wow...
gregs
Post by gregs »
maybe this will help
rletzgus
Post by rletzgus »
So, from this chart is it saying that no advance will give me the best torque? I guess I wll experiment and see what "feels" best, as I have no dyno in my driveway.
2001 GMC Sierra
4.8L
Headers
gregs
Post by gregs »
it says ignition timing from MBT (Max brake torque) aka max torque. so what the graph is showing is that you can advance your timing past the optimal point while still not hitting knock. this is why the method of advancing your timing until you reach knock and then backing it down a few degrees is incorrect procedure. the only way to know where your engine makes mbt at a given point is to have it on a dyno.
rletzgus
Post by rletzgus »
I see. thanks
2001 GMC Sierra
4.8L
Headers
