Gear Change Question
Brad519
Post by Brad519 »
I've got the Predator U7194 I'm using on my 2008 Chevy Silverado and I'm changing the gears next week. I've been told you can use the predator to change the gear ratio setting but I was unable to locate it on the predator. Is this possible and if so where is the gear setting. Thanks in advance for any help.
RE: Gear Change Question
This will require a custom tune.
Export your tunes and post them here and I'll set you up.
Brad519
Post by Brad519 »
Hopefully I did this correct.
This is on a 2008 Chevy 4wd 5.3 currently running 3.73 gears and switching to 4.88 gears. Need a tune for the new gear ratio.
PCM_617631617301 Original.grg
Original
(59.21 KiB) Downloaded 81 times
PCM_617631617301_87_Octane_Tune_modified.grg
(3.25 KiB) Downloaded 93 times
johan
Post by johan »
See how this one behaves.
pcm_617631617301_87_octane_tune_modified_488.grg
(49.73 KiB) Downloaded 81 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Brad519
Post by Brad519 »
Ok thanks. Gears will be installed Monday so I'll put the new tune in when I get the truck back.
Brad519
Post by Brad519 »
Appears to have worked fine.
Speedo is correct again.
Thanks Again for the help.
Sweet, thanks for the feedback.
Return to “Predator GM Gas”
