predator won't power on w/ac adapter
Taggert_LOA
when i plug the ac adapter in the screen lights up for a second and then goes dark and displays nothing. computer continues to search for connection. am i doing something wrong?
RE: predator won
sounds like a bad power supply.
RE: predator won
does the predator power on correctly when plugged into a vechicle??
Taggert_LOA
RE: predator won
yep i was able to install my 93 tune. i am trying to back up my dsp onto my computer. do i send the ac adapter back to you for replacement?
RE: predator won
you'd contact the reseller/vendor you got it from...
diablosport does not sell directly to consumers... diablo sells to resellers/vendors...
so, check out the packing slip from your delivery, see who it came from.... and contact them about a replacement...
Taggert_LOA
RE: predator won
kool i'll do that. in the mean time any 12v 1 amp power brick should suffice?
RE: predator won
yep, any power supply with the same specs will work...
12v, 1 amp, center positive...
Taggert_LOA
RE: predator won
bought new adapter works like a charm. thanks guys.
RE: predator won
cool!
