PREDATOR+ HP TUNE COMPATIBLITY-What can the predator read?
RE: tune
yes, if your predator was all reset and then you hooked it up to your car after it had the ECS tune, then the ECS tune is now saved as your original backup... so, you no longer have a copy of your original/stock OEM tune, unless you saved it to your pc before you restored it to your car before.
hardnoks
Post by hardnoks »
Well,now I understand.SO,WHAT happened when I did the read extra tune thing in my car?What tune did It read?And LEW,That means the "stock" tune I have labeled on my computer at home is actually the ECS TUNE,I guess.Can that be hooked up to dataviewer?
The Predator read the same thing for the backup and the extra tune.
hardnoks
Tune
Post by hardnoks »
ok.1 other thing.I cant find the area to change my password.I got the link sent to my email,but it just gets me back to the log in page to put in the email that you guys sent me.Is there no where to put in a password of my choice?Thanks for all the great info fellas!You'll make a tuner out of me yet!
RE: Tune
no, there's no where to put in or change the password to whatever you want. the password that is generated and sent to you, is your password for ever. LOL
hardnoks
Post by hardnoks »
Fabulous! :D
Hey Lew,I notice the 14.75 whichamacallit on the dataviewer for my car didn't change thru the whole log.Did I miss it?That's the a/f ratio thing right?It's a different name on the viewer.
in the dataveiwer/log, it's Equivalency Ratio / AFR...
if you had no WOT runs in your log, then yes, it will be 14.75, as that is the normal/stioch AFR that the ECM keeps it at during normal driving/cruising.
hardnoks
Post by hardnoks »
I had a WOT for a bit on the highway.I sent you that log.Did you notice the change when you looked at it?
depends.... which one was your log, which one are you??? LOL I got 5 of them last night...
hardnoks
Post by hardnoks »
Well,you're a busy guy!This was 2 nights ago,late,12-12:30 ISH.05 VETTE :D
aaah, the -11% slope... yeah, replied to ya... yup, you missed the AFR change, it's in there... your AFR changed like it should at WOT...
hardnoks
Post by hardnoks »
Next day you said write down + 5% wot,higher RPM's,+2% lower ones.
hardnoks
Post by hardnoks »
I'm going to do LOG with the "CUSTOM TUNE" in the car,then the "stock tune" and send them to you for evaluation.OK?
ok, sounds good man!
FastBlueSS
RE: tune
Post by FastBlueSS »
How much longer till TCM support?
