PE Checking & How To?
ALK
Post by ALK »
On a 07 A6 C6, how do you check and then adjust, if necessary, the PE with the 7194 Predator?
RE: PE Checking & How To?
Ideally you start with a wideband.
gregs
Post by gregs »
factory narrow band o2 sensors are ONLY accurate at stoich, so like mike said you need a wideband.
03 Silverado 1500 Z71 EC/SB
ALK
Post by ALK »
But gentlemen, then how do those whom have computer savy to run information collected by the 7194 thru DSLOGREDUX and get tuning recommendations to change PE settings without a wideband?
based on the EQ ratio in the PCM.
and I've done several hundreds of custom tunes and know what to set them at in a custom tune file...
Morgoth
Post by Morgoth »
So get a diablew tune main! Ha ha
2004 GMC Sierra 2500HD,496 w Allison 5 spd,Vararam Vr6 and Vr3,Flowmaster 50 series,TD TBS,Amsoil lubes,MSD wires,Edelbrock shocks,U7193Image
