U7134 '03 S1 PT Cruiser GT autostick
CalID 04510057AB
If I'm understanding what my CMR tuner is telling me, COT can not be adjusted/turned off in my CalID. I have fellow PTGT owners with different Calid and they have had their COT turned of by other CMR tuners.
Please enlighten me on how this works? Or in my case not work.
KB
COT can not be turned off?
can you post your tune here?
can you export it to your PC and email it to [email protected]
Its off in your tune already....
- (3.65 MiB) Downloaded 173 times
robaquaman
COT appears not to be turned off
I have the same combo ptgt auto but a different CALID. Don removed the COT from a modified 93 tune for me and my afr where unaffected all the way down to 8.3 and never any leaner at wot than 10.5. Seems there is something other than the cot that is telling the pcm to richen up. Don suggested i contact duster360 to see if he would use my datalogs to figure out the problem. Well duster360 didn't look at my logs but he did adjust my modified 93 tune so that at wot the afr stuck at 11.77 through all gears and rpms. So I'm not sure whats causing the problem but duster360 seems to have it figured out.
