PE Checking & How To?
On a 07 A6 C6, how do you check and then adjust, if necessary, the PE with the 7194 Predator?
RE: PE Checking & How To?
Ideally you start with a wideband.
factory narrow band o2 sensors are ONLY accurate at stoich, so like mike said you need a wideband.
03 Silverado 1500 Z71 EC/SB
based on the EQ ratio in the PCM.
and I've done several hundreds of custom tunes and know what to set them at in a custom tune file...
