Custom Tune with procharger
Here is the deal:
I have a procharger kit that I am putting on my truck. It comes with a Predator with a custom tune loaded onto it from Procharger.
My question is:
Can the transmission settings still be adjusted when loading a custom?
The guy from procharger said that they do not touch the transmission settings. I really don't want to lose the firmer shifts and adjustability. Thanks.
My question is:
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Predator
V.9r11
RE: Custom Tune with procharger
For anyone intreasted:
The custom tune is only PCM, and the transmission adjustments are all still available even with the custom tune. Good thing!
Predator
V.9r11
Predator
V.9r11
BlownHemi
Did you find a way to use the transmission settings with the ProCharger Tune. Have had the same problems but never been able to use any of the Diablo Trans Settings.
yeah like I stated above the tranny options are still there to adjust when you load a custom tune
Predator
V.9r11
Predator
V.9r11
Hi all, i have a procharger tuner kit for a 2006 ram 5.7 hemi but i need the tune for a diablo predator
were can i get it, or you butch1581, can send me the tune? tnkss
His tune won't work for you. Check the Downloads section to see if theres a U7137 Procharger CROM. If not, you gotta get ATI to send it to you.
BlownHemi
Re: RE: Custom Tune with procharger
From what I have heard our tunes will not work for you because of the tunes are tied to a certain VIN. You need to get a tune from ATI or a custom tune. Unless your able to get someone to set someone else's tune up with your VIN for your vehicle.mexcomp wrote:were can i get it, or you butch1581, can send me the tune? tnkss
Yes it is, U7137 is a 2006 dodge ram 5.7 hemi, must work, I have a lot of time battling, and considered selling the kit, is brand new on the box, i tink use 39.5 lbs injectors, diablo predator and i think 2 bar map sensor but im not sure, i can buy the 39 lbs ford racing injectors the map sensor, and the diablo, i would need only the tune for the diablo, i hope you can help me tnkss
You need to get with a good CMR tuner, that thing could be dialed in via email if you have a wideband in it.
BlownHemi
Personally you are better off getting a custom tune made to handle everything. The procharger tune only scales the injectors, and even then it is scaled to 42lb injectors to make up for the lack of fuel pressure. Atleast thats what I was told when trying to deal with them a while back.mexcomp wrote:Yes it is, U7137 is a 2006 dodge ram 5.7 hemi, must work, I have a lot of time battling, and considered selling the kit, is brand new on the box, i tink use 39.5 lbs injectors, diablo predator and i think 2 bar map sensor but im not sure, i can buy the 39 lbs ford racing injectors the map sensor, and the diablo, i would need only the tune for the diablo, i hope you can help me tnkss
There are a lot of good tuners that visit this site, i'm sure they would be able to fill the need you have. If you didn't buy your kit through procharger or one of their authorized dealers i doubt they will be willing to help. I can't even get responses from them regarding my tune problems that they wrote.
Good Luck
RE: Re: RE: Custom Tune with procharger
Hi, butch1581 please sell me the tune, only need the tune to install it, tnkss bye bye
the tune wont work, it is tied to my VIN
Predator
V.9r11
Predator
V.9r11
I am still looking for someone to give me a custom tune for my truck. Anyone intrested?
Predator
V.9r11
Predator
V.9r11
Lots of CMR tuners out there that would love to have your business...
