AFR
jsk06c6
AFR
Post by jsk06c6 »
During a WOT, what AFR should I be looking for at minimum?
Mine went down to 11.89, is that bad? Too rich? Lean? Thanks...
jimmybuckets
RE: AFR
Post by jimmybuckets »
What are you driving and what motor does it have in it
tonys01c5vette
RE: AFR
Post by tonys01c5vette »
c6 new style corvette
jsk06c6
Re: RE: AFR
Post by jsk06c6 »
tonys01c5vette wrote:c6 new style corvette
Yep, 2006 C6. Going to need new tires quick, it rips them up real good on the 1-2 shift. Not a chirp, is spins/rips them up real good. :lol:
2006 Victory Red LS2 1LT M6, Halltech Stinger, 4" round B&B Bullets, B&B x-pipe, CCA Catch Can, Aluminum Throttle body spacer, Z51 sway bars
    RE: Re: RE: AFR
    11.89 is rich... provided you have your normal driving/cruising ltft's dialed in to the range of -0.xx to -2.xx, then you can pull out some fuel from the PE rpm ranges to lean it out some more...
    you would want to get your WOT AFR at around 12.6-12.8 on the Predator...
    jsk06c6
    Re: RE: Re: RE: AFR
    Post by jsk06c6 »
    06MonteSS wrote:11.89 is rich... provided you have your normal driving/cruising ltft's dialed in to the range of -0.xx to -2.xx, then you can pull out some fuel from the PE rpm ranges to lean it out some more...
    Thanks. This was an out of the box diablo tune. Just looking to see where it has me as a start and what I'm shooting for, appreciate the help.
      Return to “Predator GM Gas”
