During a WOT, what AFR should I be looking for at minimum?
Mine went down to 11.89, is that bad? Too rich? Lean? Thanks...
AFR
jimmybuckets
Re: RE: AFR
Yep, 2006 C6. Going to need new tires quick, it rips them up real good on the 1-2 shift. Not a chirp, is spins/rips them up real good.tonys01c5vette wrote:c6 new style corvette
2006 Victory Red LS2 1LT M6, Halltech Stinger, 4" round B&B Bullets, B&B x-pipe, CCA Catch Can, Aluminum Throttle body spacer, Z51 sway bars
RE: Re: RE: AFR
11.89 is rich... provided you have your normal driving/cruising ltft's dialed in to the range of -0.xx to -2.xx, then you can pull out some fuel from the PE rpm ranges to lean it out some more...
you would want to get your WOT AFR at around 12.6-12.8 on the Predator...
Re: RE: Re: RE: AFR
Thanks. This was an out of the box diablo tune. Just looking to see where it has me as a start and what I'm shooting for, appreciate the help.06MonteSS wrote:11.89 is rich... provided you have your normal driving/cruising ltft's dialed in to the range of -0.xx to -2.xx, then you can pull out some fuel from the PE rpm ranges to lean it out some more...
