Changing parameters after tune is loaded
Why after loading my custom tune (or any tune) when I go back in to modify the transmission options are gone? I have to load my stock tune first then go to load the tune again in order to get the tranny stuff back?
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Predator
V.9r11
RE: Changing parameters after tune is loaded
Sounds like you are onlyloading a custom PCM tune, and not a TCM tune?
no, I am loading a custom PCM tune and choosing the "perf. Trans tune" but when I go back in afterwards the trans stuff is gone?
Predator
V.9r11
Predator
V.9r11
it also does the same thing if I load a "canned" tune
Predator
V.9r11
Predator
V.9r11
Did you try modify canned tune option? if you do that you can modify alot of options in there.
07 CHARGER R/T: 6.1L Cam, springs, & rods, Dynatech headers W/ Hi-Flow Cats, AFE CAI, Catch Can, Flowmaster Catback, Jet 180 T-Stat, Hotchkis Sways. All installed by myself, I paid no one for installation of any mods.
Future mod wishlist: Pedders suspension, heads, bigger cam, LC-1, & Nitrous.
I can no longer use a canned tune. I have to use the "custom tune" from procharger. I am not sure why it does this, but its really annoying anytime I want to cahnge a tranny setting, I have to load the stock tune, then re-load the custom tune......
Predator
V.9r11
Predator
V.9r11
This is fixed in 9r09.
I have the 9t09e Crom right now, I will see if the 9r09 is any different. Thanks!
Predator
V.9r11
Predator
V.9r11
I have tried all the updates and still have this problem. It is really annoying!
Predator
V.9r11
Predator
V.9r11
TooCoolHemi
Re: RE: Changing parameters after tune is loaded
Ya,right.Evidently not.When are you guy's going to really fix this?No telling what it's causing to happen with the tool not seeing a tcm calid.mikel wrote:This is fixed in 9r09.
Butch the way to make tcm option's to show up on mine,is go to show calid before you load custom tune or makeing any adjustment's.Making the tool look for a tcm calid (that it's not seeing) make's the tool show tcm option's.Post up if this work's for you so other't can do this to get there tool to work like it should.
RE: Re: RE: Changing parameters after tune is loaded
Cool, thanks man. I will give it a try tomorrow... Hopefully this will be fixed eventually.
Predator
V.9r11
Predator
V.9r11
it didnt work for me... This is lame
Predator
V.9r11
Predator
V.9r11
- white_lightning
Re: RE: Re: RE: Changing parameters after tune is loaded
try updating to Crom 9r12.butch1581 wrote:it didnt work for me... This is lame
TooCool's trick has worked for me and a few others with '05's & '06's.
to add some detail to what TooCool said:
plug Predator into truck. on main screen, select "daignostics" then select "show calibration #" and it should show both your PCM calibration # and TCM calibration #.
if this process does not show your TCM calibration #, your tuner is not communicating properly with your TCM and you need to call Diablo's tech support.
if it shows your TCM calibration#, you should be able to make changes to the TCM tune.
- white_lightning
have you considered getting a custom TCM tune too? I can write you a pretty good TCM tune.butch1581 wrote:I can no longer use a canned tune. I have to use the "custom tune" from procharger. I am not sure why it does this, but its really annoying anytime I want to cahnge a tranny setting, I have to load the stock tune, then re-load the custom tune......
I do want to get a custom TCM and PCM tune, but everyone I have contacted says I need access to a dyno or need to bring the truck in. I think I sent PMs back and forth wit you about this too. You just do TCM tune right? How much to get this thing dialed in? I really want a towing tune and an everyday perf. tune to work with my supercharger.
Predator
V.9r11
Predator
V.9r11
