Denali - Speed limit off is not working
can you load the diablo tune then export last tune written please?
Here it is.
- PCM_628983631269_Modify_Stock_Tune_modified.grg
- (1.25 KiB) Downloaded 195 times
- PCM_628983631269.grg
- (66.67 KiB) Downloaded 187 times
why do you call it modify stock tune?
Again, I do not believe the tool is offering you a 'Diablo Tune', can you please verify that??
This is why, when I save it in my computer it will save as the name above.
After selecting GMC --> Yuken--> 6.2
It gives me the option to install the Diablo Tune filea fter saving the original file, and then I modify the parameter and re-install it once again with the new parameter which is Speed limit removal.
So I belive that I have installed the Diablo tune file which came with the tool.
Is that Right!!
Is that Right!!
My records indicat ehtis calibration is not yet supported by the predator, thus it should give you a message saying the calibration is not supported, and ask you to choose modify stock tune to allow the Predator to save the backup file.
In this case, there would be no option for 'Diablo Tune' in the Predator menu.
no, the diablo tune is called diablo tune.
You will be supported in the next revision.
Good to hear.
