Reprogramming cam phaser tables
alpineray
Post by alpineray »
I have purchased a U7151 Revision 9r11.
I'm working on a 2007 Ford F150 with 5.4 3 valve motor.
I want to install cam phaser limiter kit from comp cams, they say the computer must be reprogrammed by adjusting phaser tables to a maximum retard of 20 degrees. I have not been successful in finding someone that can email a program that will do this. Has anyone installed phaser limiters or the phaser blocking kits available from livernois? I am running a stock motor with no modifications, just tired of the cam phaser noise that exist even after all new timing componets, phasers, sensors, etc.
RE: Reprogramming cam phaser tables
Probably not something anyone wants to do via email, nor would I understand wanting to do this with the stock cams??
Youre going to lose power....
alpineray
Post by alpineray »
My email help request response from Diablosport was this
"You can contact any of our Ford custom tuning dealers for a custom tune to do this."
One of "your Ford tuning dealers" told me to buy a Diablo Predator and he would email me a tune that would do this.
For the last week I have tried to talk to him again but he is always on the dyno or with a customer or just not there. Is there a list of other shops i can contact?
http://www.diablosport.com/index.php?mo ... lay&pid=32
top right hand corner of the screen ;)
FrankenFord
Post by FrankenFord »
To the OP: I just installed the phaser locks on a 2006 F150. The locks are slightly different if the fact they do not allow ANY phaser movement. I purchased my programmer from RPMOutlet. A guy there named George can build you a custom program. He is actually going to set my tables to zero degrees. They do free programs for life if you purchase from them. If you purchased elsewhere they charge a hundred bucks for a tune then a nominal fee to tweak tunes later if you change something.
When all else fails, get the smoke wrench.
Return to “Predator Ford Gas”
