NEW U7137 UPDATE..
TooCoolHemi
RE: Re: RE: NEW U7137 UPDATE..
Post by TooCoolHemi »
Jezze Mike that was a slow response.I'll give it a try.
TooCoolHemi
Sorry Guy's it did'nt resolve the issue.At least not on my 05.
can you please describe the problem in detail for me then?
TooCoolHemi
When loading the 93oct. tune i have tcm option's.Any change's you want to make to the tcm have to be made at this time.Once it's loaded into the truck and go to load my custom tune i have no tcm option's.If i want to make any tcm change's i have to go back to stock and reload the 93oct. tune.This is very time consuming and pain to want to make any tcm adjustment's
OK, this had been brought up in the past, and I made sure that this latest crom gave you the option to select the canned TCM tune if you had a Custom PCM tune loaded, let me look into it some more.
TooCoolHemi
Thank's Bro!!!
butch1581
Post by butch1581 »
yeah thanks man. I have the 9t09e Crom right now, I will see if the 9r09 is any different.
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
Ramathorne
Post by Ramathorne »
whats the difference between 9t09e and 9r09???
I downloaded the one at the beginning of the thread on september 28th
Any updates since on the U7137?
9t09e and 9r09 are the same...
butch1581
Post by butch1581 »
shoot, then I will still have the same issue if those 2 croms are the same. Any luck finding out why our TCM options go away?
Predator
V.9r11
butch1581
Post by butch1581 »
Any luck on this, Mine is still doing the same thing
Predator
V.9r11
are you running 9r09??
You have 9r08 in your sig still....
butch1581
Post by butch1581 »
Yes I am running the 9t09e as stated earlier
Predator
V.9r11
diamondave5
Post by diamondave5 »
i just ordered a 7137 for my 08 1500 with hemi, do i need to update it or will it be updated already since its new? and how will i know when i get it? thanks
diamondave5
well got it figured out, it said i needed an update when i hooked up, so messed around on pc and got that taken care of....works
