No SUPPORT for a 2010 Dodge Ram 2500 Hemi
JHeavy
Post by JHeavy »
Mike, I downloaded "u7137_9t09e_212.crom" and it works, thank you.
Unfortunately I can't change the TPMS settings. My low pressure light has been on for the past 6 months due to aftermarket tires. I was really hoping I could change the pressure settings. Should this be possible?
Also, is there a difference between the 9t09d and 9t09e, regarding the RAM 2500 Hemi?
Thanks.
what happens when you try to change it?
9r09e has a few more fixes.
JHeavy
Post by JHeavy »
It doesn't allow me to change it. Doesn't show anything about pressure or TPMS.
Thanks Mike
pressure calibration
JHeavy
Post by JHeavy »
Mike, here is what I'm looking at.
Cooling Fans AC Off
Cooling Fans AC ON
Idle
MDS
Part Throttle Upshit
RPM Shift Points
Rev and Speed Limits
Throttle Calib
Tire Size
WOT Fuel
WOT Spark
I don't know if if makes a difference, but the 2500 trucks have a High/Low pressure settings for the tires. Light load is 60 front, 45 rear. High load is 70 on all corners.
Thanks for getting back to me so quick.
JHeavy
Post by JHeavy »
Oh, and Quick Ajust only shows tire size.
checking it out....
JHeavy
Post by JHeavy »
Mike,
I see there is a new update "u7137-9r09.crom". I am still running "u7137_9t09e_212.crom". The crom numbering system doesn't make since to me. Should I update?
Thanks.
Turns out there was no adjustment for tpms available for the newer 2500 rams, I'll look into the possibility of changing from the high/low settings.
JHeavy
Post by JHeavy »
Great, thanks Mike.
Deltamac
Post by Deltamac »
I just received my new Trinity and when I go to upload the latest downloads the following happens:
- I enter the serial number: 6JTEP1F-1
- Updates come up but they are all V.1R07 series
- How do I get the u7137_9t09e_212.crom updates?
Thank you for helping out a Newbie.
9t09 is a predator crom, use the update listed for U7137, or use the latest dsdl 2220 and it will automatically load ALL updates to the tool for you.
