Predator Logs MAF in g/s how do i get a HZ value from this
like it says. im logging in grams/second and need Hertz
RE: Predator Logs MAF in g/s how do i get a HZ value from th
check the full parameter listing... there is a MAF PID that logs the Hz already...
go through 'em all and look for it.. it's in there...
probably need to open DV if it is not in the predator.
aaaah.... you have a 7198... didn't say that in the beginning... heh...
yeah, your older vehicle may not report that with just the predator then...
newer ones do....
try using a laptop and the Dataviewer program to log... you'll have a lot more parameters available to ya in the dataviewer app to log... especially once you choose to view the infrequently used PID's...
the predator's have a limited amount of space/memory, so they don't have the entire available PID's stored in them that you can log, so see if it's listed with the data viewer - the dataviewer uses the predator as a pass-through device to read your pcm directly, and can log whatever is in and reported by your pcm...
cuz I dunno if there is a direct conversion for grams per second to hertz man...
newer ones do....
k, so your pcm does not report it then...
I did a few searches online, and have not found any conversion for g/s to hz at all man...
