Need help tuning my truck.
bburesh
Post by bburesh »
I purchased a new Diablo Predator U7198 for my 02 Chevrolet Silverado ext cab z71. an have a performance tune set but would like to change some of the parameters to wake it up some more. 2nd gear wont go for anything.
I have a
-Spectre CAI
-Street Performance Throttle Body Spacer
Thanks, Brian.
gregs
RE: Need help tuning my truck.
Post by gregs »
so whats the question?
03 Silverado 1500 Z71 EC/SB
bburesh
Post by bburesh »
Like what should I change shift points at? An if there is anythin I can change so 2nd gear won't be a dead zone...
for starters, do some data logging to see where your average fuel trims are at, and adjust the fueling accordingly...
bburesh
Post by bburesh »
Alright I'll do that an let ya know where I get with it.
gregs
Post by gregs »
you could raise your rev limiter and change the 1>2 shift to 6000 rpm, that will help 2nd gear get into the power band faster. But do like mike says and get the fuel trims corrected first. Are you running the 87 octane or the diablo tune?
or, you could do what I (Lew) said, which was to log your fuel trims... since Mike hasn't posted in this thread at all... :lol: :lol:
bburesh
Post by bburesh »
I am running the diablo tune i had it on 87 octane but changed it bout a month ago. but ill get those fuel trims correct then ill look at messin with shifts.
bburesh
Post by bburesh »
i took it ff 87 because all i put in my truck now is 93 octane
gregs
Post by gregs »
:punisher: oops i meant Monte not Mike :punisher:
