Stuck In Gear
Stuck In Gear
I have a 06 Dodge Magum 3.5. I have the 9r08, 91 perf. tune, increased shift firm, disabled auto stick. When i get to a stop it get s stuck in 3rd gear will say 3rd gear in dash and then wont go out of 3rd have to shut car off and restart it ???
- j.mike@diablosport
RE: Stuck In Gear
Can you please double check the revision code of your tool? The most recent rev for the U7136 should be 9r06. Are you saying that you are not able to manually downshift the car to a gear lower than 3rd when in Autostick mode?
Diablosport Sales Team
Caffeine Engineer
Please do no PM me! Send an email to [email protected] if you need to contact me.
Caffeine Engineer
RE: Stuck In Gear
yeah when it it get stuck it gets stuck like it will show 3 in the dash but wont downshift even if i put in "D" and back into autostick nothing tried lots of different combinations ..........
RE: Stuck In Gear
Is the tool on the current revision?
Please give me the code next to the word Predator on the main menu:
"v.#r##".
"v.#r##".
Caffeine Engineer
Caffeine Engineer
RE: Stuck In Gear
I said up top it is 9r08 but actually its the 9r06 for the u7136
RE: Stuck In Gear
It just happened to me again. seems to only happen when stopped to WOT.....??
RE: Stuck In Gear
also yesterday my tranny popped a code 1001 "unknown" and today it popped a po700 code what to do ???
RE: Stuck In Gear
Sounds like a communication issue in the harness maybe?
RE: Stuck In Gear
harness? from the predator or..? everythings seems ok back to stock it only seems to happens when i use the disable autostick feature that i like using. Ill have to wait till the weekend really to investigate it more.. wrk..then home..now dark haha
RE: Stuck In Gear
there may be a TCM update available at the dealer to fix this.
