2010 Ram Hemi Tranny Jumping And Rough
juankatrina
RE: Re: RE: 2009 Ram Hemi Tranny Jumping and Rough
Post by juankatrina »
Yes I cleared it and reloaded again after I noticed I was looking to install it from wrong screen.
juankatrina
blazingzz
Post by blazingzz »
Ive noticed the jumping twice at about 60mph then punching it. Seems as if you have resolved most of it. My issue with the idle is still there when i come to a stop at a red light it drops down to about 500 and stays there unless i tap the gas pedal or turn the steering wheel to draw some power then it will jump back up and stay there. Also on the shift firmness is still the same, that I know of the trans is the same in an 05 to an 09. Im just wondering why mine cannot shift as firm as my old 05 or my fathers current 05. If you could do something about the shift firmness and the idle that would be awesome. The shaking you have almost completely gone maybe a few more tweaks.
blazingzz
Post by blazingzz »
Johan, is there anything else you guys are going to try to fix this.
blazingzz
Post by blazingzz »
OK its been a week and no response. This is the crap i do not like from companies. Some one respond soon with something. Even if its ..(were looking into it). I dropped SC for having issues with there tuning and poor customer service. Please don't get like them. I like your product but I will not deal with poor CS. Everything was good, posted up issues on this forum, someone made an effort to fix it pretty fast. Well there is still an issue and I know you guys are not like this, so someone please respond.
**"Ive noticed the shaking a few times at about 60mph when punching it. Seems as if you have resolved most of it. The times it does not shake it seems as if the truck does not downshift far enough to take off fast. Seems as if every time it don't shake it could go another gear down, because the truck just don't take off like it used to. My issue with the idle is still there when i come to a stop at a red light, it drops down to about 500 and stays there unless i tap the gas pedal or turn the steering wheel to draw some power then it will jump back up to about 700 and stay there. Just saying I would like it to stay at 700 and not drop down when stopping. Also the shift firmness is still the same. That I know of the trans is the same in an 05 to an 09. Im just wondering why mine cannot shift as firm as my old 05 or my fathers current 05. If you could do something about the speed of the shift and the firmness of it. The shaking I have is almost completely gone maybe a few more tweaks from you guys." The Biggest thing i really would like resolved soon as possible if you had to focus on one thing is the shaking when punching it and the speed and firmness in the shifting. Thank you guys
blazingzz
Post by blazingzz »
please export the last tune written and post it here so we can make sure it is being loaded properly.
blazingzz
Post by blazingzz »
will get that tonight for you thank you
fitter1
Post by fitter1 »
Hey I'm running the 9t09d I up loaded it from another thread on here for 09-10 Ram Hemi 91octane tune. I hope you can help me out with this info? I have not changed any of the parameters. I have noticed the shudder has come back at about 35-45mph when I floor it to pass in traffic bot it stops when I peddle it a bit.
I posted about it before but I have been doing lot's of City driving lately and have not needed to use the loud peddle that much....
If you need more info about the tune please pm me proper instruction on How-To pull info off tuner.
Thanks.
09Laramie
Post by 09Laramie »
I encountered the shaking again today- first time since loading the custom tune from Johan. This time, shaking happened shortly after getting on the gas around 35mph, kept my foot down, and the shaking stopped once I got a little above 40mph. Last tune written is attached.
fitter1 wrote:If you need more info about the tune please pm me proper instruction on How-To pull info off tuner.
See links below for instructions.
09Laramie wrote:
juankatrina wrote:ok how and do I get that tune file from my tuner? What does it consist of? Not sure exactly what you mean or how to get it.
Downloading tunes from the tool
blazingzz wrote:What is the proper way to add it to the tuner. Do you take the truck back to stock and then do a tool update or do i add tune file to the tool.
Sending custom tune to tool
Found both of those documents, and some other interesting info on the Support Documentation page.
PCM_68059434AB_pcm_68059434ab_perf_93oct_modifi68059434AB.drg
Last tune written
(4.25 KiB) Downloaded 231 times
johan
Post by johan »
This is very odd.
Attached are two files, please try them out and let me know. Both are still 93perf based tunes here.
Thank you for working with us on this.
pcm_68059434ab_pcm_toon_002.drg
(86.61 KiB) Downloaded 190 times
pcm_68059434ab_pcm_toon_001.drg
(86.66 KiB) Downloaded 216 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
blazingzz
Post by blazingzz »
Johan here is my last tune written sorry for the delay alot going on around here too...
PCM_68059436AB_update_last_tune_written_10-29-168059436AB_modified.drg
(4.25 KiB) Downloaded 197 times
blazingzz
Post by blazingzz »
my truck also seems as if there is a small pause even at shifting just driving normally. It just does not shift right all together. It just needs to shift right into the next gear normal driving or wot there is just to much of a pause and no where near firm enough. Thanks
09Laramie
Post by 09Laramie »
johan wrote:This is very odd.
tried the 002 tune today, and couldn't reproduce the shaking. I figure I'll try the same tune again tomorrow (Friday), and then the 001 tune over the weekend.
Ramathorne
Post by Ramathorne »
This is a wide spread issue, more and more are complaining of this
I am waiting for an updated download
