2005 Mustang V6 U7140
TJFT
Post by TJFT »
I have a U7140 Preditor and I did a parameter change on the Tire Revs for proper Speedometer range for a set of 18" Tires. I did as follows: took the 20168 and devided it by the tire diameter of 18" and came up with 1120 and entered that into the tune. I have since driven the car and I think its not correct as I was flying down the road and that was at 40 MPH and prior to ever tuning the car I recognized what 40 mph felt like..this seems more like 70mph...any help?
RE: 2005 Mustang V6 U7140
What size tires are you running and in what format do you need to diameter?
No way thats right, maybe 18" rim, not tire.
Also, it is 20618.
TJFT
Post by TJFT »
Mike the instruction that came with my manual shows in two different places 20168
TJFT
Post by TJFT »
Man did I goof it up...diameter is 27"..lack of sleep will do that, but Mike I did read tonight to double check and the U7140 did state the calculation to be 20168..is this a misprint as I have not DL the new updates yet. Thanks Tom
Vas@Diablosport
Post by Vas@Diablosport »
You are correct, the formula is 20168 divided by 27 which would be 747 revs per mile.
No, i don't work here.
VinSpain
Post by VinSpain »
hi, i've 235-55-20" in my 05 V6 stang & i try to change that in my predator but no way how 2 do it, it appears in parameter 3,29 i divided 215/65 = 3,0 (215-65-16 stock wheel i guess ), what i have to do? how can i put the correct INCH & REVS per mile
P.S : sorry 4 my bad eng :)
Return to “General Questions”
