Can the Predator change the settings on the Puck???
justinhuffman
I have just ordered a puck and I am of the understanding that the puck has a toggle switch to change the settings, but my Predator programmer gives you the option for "Puck Settings" on its menu. Do I use the Predator or the Puck toggle switch to adjust the setting on the Puck?
Dodgezilla
RE: Can the Predator change the settings on the Puck???
Toggle switch.
Your Predator has the option for "Puck tunes" which is just a different program that deletes the pressure so you can use the Puck to add the pressure you want....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
justinhuffman
Re: Can the Predator change the settings on the Puck???
justinhuffman wrote:I have just ordered a puck and I am of the understanding that the puck has a toggle switch to change the settings, but my Predator programmer gives you the option for "Puck Settings" on its menu. Do I use the Predator or the Puck toggle switch to adjust the setting on the Puck?
justinhuffman
RE: Re: Can the Predator change the settings on the Puck???
Thanks for the response, but I'm still a bit confused. Will I need to tune the predator in the "puck tunes" menu to correspond with the toggle setting I have the puck set to? Or will the puck work without tuning it with the predator?
05 3500, 6" Superlift, 22" wheels, 37" tires, Bushwacker flares, Diablo Predator,Puck, Quadzilla boost fooler, K&N intake, 4" Turbo back exhaust
Select stacker tunes(puck tunes), pick the one you want, then add pressure by turning the puck to the opposite of the notch(60 HP) or the side w/ the notch(90 HP) which adds different amount of pressure as well. The instructions that come w/ it say the opposite sides for 60 & 90 but they are wrong. HTH!
2006 CTD QC 4x4 w/ some goodies
Dodgezilla
To add to the last post, the predator setting you choose has nothing to do with what puck setting you run. Your truck will run fine on Puck Stack tunes even if the Puck is off. Now, running the non-stack tunes and then using the Puck too could cause some issues with high pressure and is not recommended for extended periods.....
