How should I set the fan settings to get the factory operation? I'm not crazy about the fan running all the time, and I'd like to set it back. I definitely like the fact that I can set them when I want, however. If no one can enlighten me on the factory settings, maybe just a definition of the terminology for the fan settings below would do. I can take it from there.
AC off high MPH high speed fan on temp
AC off high MPH low speed fan on temp
AC off high MPH medium speed fan on temp
AC off low MPH high speed fan on temp
AC off low MPH low speed fan on temp
AC off low MPH medium speed fan on temp
AC on high speed fan on temp
AC on medium speed fan on temp
AC on low speed fan on temp
Thanks!
Deafult Fan Factory Settings
RE: Deafult Fan Factory Settings
Factory setting can be viewed by selecting 'stock tune', then modify tune.
You will see where the temps are ste for stock.
In case anyone else is interested. My default Fan settings are as follows (2007 Charger RT):
MyDefault PerfCAI Description
226.39 199.39 AC off high MPH high speed fan on temp -
217.39 190.39 AC off high MPH low speed fan on temp
226.39 199.39 AC off high MPH medium speed fan on temp
226.39 199.39 AC off low MPH high speed fan on temp
217.39 190.39 AC off low MPH low speed fan on temp
226.39 199.39 AC off low MPH medium speed fan on temp
226.39 199.39 AC on high speed fan on temp
217.39 190.39 AC on low speed fan on temp
226.39 199.39 AC on Med speed fan on temp
Mike,
I've noticed that my fan kicks in when I put it in Park. Is there a separate setting when you are in Park that i missed?
Mike,
