When I connect the Predator U7135 to my 300C, I get a message saying that I need to update the calibration. I connect the Predator to 2 different PC's, using the DS Downloader I just downloaded form Diablosport.com, and it takes me right ot the calibration update screen. When the PC tries to download the update, I get a warning : An error occured while trying to retrieve data, blah, blah, connecte to the internet, blah, blah, Firewall...
I have allowed DS Downlader access throught he firewall, and I've tried turning off the firewall altogether.
Suggestions?
Thank you.
2005 300C Predator update
BlackHemi2005
- DS.JPG (77.59 KiB) Viewed 2161 times
RE: 2005 300C Predator update
we're on it
fixed.
BlackHemi2005
Okay, I got it... However, the speed control doesn't work, anymore.
When you start the car, you can turn on the speed control, and the light will turn on. As soon as you hit 10-20 MPH, the light turns off, and cannot be turned back on until the car comes to a complete stop, again. There was a DTC in the ABS module for a calibration mismatch (Sorry, cannot recall the exact DTC... it was 10:00PM when I finally got home from work last night). I cleared the DTC, and it has not come back. However, the speed control still will not work. I have no other DTC's in any modules on the vehicle, with the possible exception of the EVIC, which my scan tool will not interface with. I have good wheel speed readings from all 4 sensors. The only other thing I noticed, is when I monitor the PID's for the speed control switches, the PID's do not change. All of the switch PID's remain "inactive," regardless of whether I am activating the switch, or not. I have returned the tune to stock, and the speed control still does not work.
Thoughts?
Thank you.
Thoughts?
Thank you.
BlackHemi2005
