U7194 Vehicle Swap Question
Brad519
Post by Brad519 »
Ok I have a U7194 with revision 9r18 that I'm currently using on my 08 Silverado. My questions is can this same Programmer be used on a 2010 Camaro SS? I know I would have to "unmarry" the programmer from the truck but after that can I just hook it up to the Camaro or is this possible.
RE: U7194 Vehicle Swap Question
yes, that is the same model predator that can be used on the camaro as well... but like you said, you'd have to restore the original backup stock tune to the truck first in order to unlock/reset the predator... and then you could use it on a camaro...
Return to “Predator GM Gas”
